Exterior Talk about your rims, body kits, and other exterior mods here.
2013 Lancer Sportback GTS Weak Rear Shocks
Old Jun 17, 2013 | 02:23 PM
SRC1225's Avatar
Default 2013 Lancer Sportback GTS Weak Rear Shocks
Hi All,
I recently put on a set of 1" hub-centric wheel spacers to beef up the traction, stance and appearance, and the car really looks awesome! But now, whenever I hit a bump or dip in the road. the back-end is bottoming out on the tires, hard, even with an empty cargo space. Add 20-30lbs, and the rear is damn near dragging on the tires. What's the best/easiest way to really stiffen up the rear shocks or raise the back end some so that stops?
Thanks!
Scott
***8/20/13 UPDATE***
In lieu of spending thousands, I got a 6" X 1" Coil Spring Rubber & sliced it into 8ths, got the car on a lift and had them pounded in with a rubber mallet, one every 90 degrees, 4 per coil. Presto! Problem solved, and it actually increased the rake of the care in a great way!!
Attached Thumbnails 2013 Lancer Sportback GTS Weak Rear Shocks-012.jpg   2013 Lancer Sportback GTS Weak Rear Shocks-015.jpg
Patrick
24
Apr 18, 2020 06:55 AM
SRC1225
Feb 25, 2015 03:06 PM
nickideenster
May 30, 2013 07:26 PM
mphil804
18
Jul 29, 2006 10:37 PM
dreamz
Dec 1, 2005 09:18 PM
