Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
2002 diamante loses all gears
Old 07-31-2014, 08:13 PM
srinath's Avatar
Default 2002 diamante loses all gears
No nothing, not even reverse. My wife says it did that without any untoward noises and it even rolled easy, as she was leaving a light, basically it started to move and then gave up.
Could it be electrical ?
Thanks.
Srinath.
Old 08-01-2014, 12:35 AM
Akzle's Avatar
yes it could. and probably is.
Old 08-01-2014, 10:35 AM
srinath's Avatar
Could you point me to a more specific component ?
The car literally like dropped into neutral after accelerating from a stop. Like got up to 15-20 and neutral.
Shifter and whatever else all feel normal.
Thanks.
srinath.
Old 08-01-2014, 02:30 PM
Akzle's Avatar
'literally like', those words mean two different things.
It either literally did, or it did like...
Presumably the box is actually in neutral, otherwise its a clutch issue, so the electrics around those.
Old 08-07-2014, 12:03 PM
srinath's Avatar
Default No oil pressure
That transmission has no oil pressure. Wavy washer strikes again ?
Cool.
Srinath.
Old 08-20-2014, 08:10 AM
srinath's Avatar
Default Toast
OK the transmission was toast. Wavy broke, chewed the pump and the housing on that side cracked and started to pop its guts ...
However, that transmission was not needed to fix the car, I had a spare pulled from my other diamante ... a known good one, cos tha tcar snapped an accessory belt and that wrapped up in the timing belt and ruined the motor ... so I know transmission was good. LOL.
Anyway we put a new wavy, and new clutches in that transmisson and put that in the car.
The thing is now this transmission has a over rev on shifts. Not just 3-4 but also 2-3.
What causes the thing to do that ?
The transmisson guy said the fluid came out very dirty, which was why he put new clutches in - there was visible wear on the clutches.
Thanks.
Srinath.
Old 09-03-2014, 03:14 PM
srinath's Avatar
OK That transmission works, I had 2-3 shift flare, and we fixed that by drilling the hole in the separator plate, and it went away.
But, 3-4 has a flare - which we cant tell why. But this car did that on its prior transmission too. Maybe the car, like an ECU or something has an issue.
Anyone have a 3-4 flare and if so how did they fix it.
Thanks.
Srinath.
Old 05-02-2016, 07:21 AM
robert740il's Avatar
pulled up and parked. came back later and lever moved but car would not go into gear. transmission 5 quarts replaced and is doing fine. when i hooked up the old battery it fried and now having electrical issues. dash lights won't come on and power windows and locks don't work. found 1 bad fuse looking for others.
Old 05-10-2016, 08:28 AM
did a flush with castrol foreign car tranny fluid and is smooth as silk right now. all gears working.
elmiserable
01-20-2009 08:18 PM
elmiserable
01-20-2009 08:13 PM
touble
08-30-2008 06:58 AM
bryan
03-02-2008 04:56 PM
dlwdracos
06-13-2006 06:25 PM
Quick Reply: 2002 diamante loses all gears
