Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Keyless entry remote fob
Old 01-09-2017, 07:47 PM
ZerOlivier's Avatar
Default Keyless entry remote fob
Hi there,
I'm wondering which models of remote I should have to open/lock my car!
My car is: Mitsubisbi Diamante 1995 E-F36A
I bought a remote model: GQ43VT4T (Mitsubisbi)
But I cannot setup the remote, so is there a remote for this car?
I have contacted my dealership but he doesn't know and I don't have the Owner manual
Thanks
Olivier
Old 03-04-2017, 11:15 PM
vlopez1130's Avatar
check a program your remote website google search it. They provide instructions for programming. Sometimes they have you use a paperclip to jump a couple of connections but its different for every car.
Old 03-04-2017, 11:26 PM
vlopez1130's Avatar
1. Locate the Data Port.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port with a suitable jumper wire, leave jumper wire connected throughout the programming procedure. Make sure you know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, turn the ignition switch to the ACC position and then back to OFF 3 times. Note: The doors will automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK button on the transmitter to be registered three times within 10 seconds. Upon successful programming, the door will lock and unlock once.
6. If there are two remotes, register the first, then register the second. Repeat step 5 within one minute to program second remote. After completing the second programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition.
Old 03-04-2017, 11:27 PM
vlopez1130's Avatar
those are for a 1999 not sure if it will work but its worth a try. A paperclip will work as a jumper. I had to do this for another car
Old 03-09-2018, 12:21 PM
hichamaziz's Avatar
check a program
Casper_1984
05-07-2008 09:30 PM
mitsu01eclipseGT
02-26-2008 11:28 PM
ap1999monterosport
03-22-2007 01:50 PM
ToolMan
02-19-2007 09:23 AM
rdublu
11-24-2006 03:18 PM
Quick Reply: Keyless entry remote fob
