08 rear glass hatch opening?
Old 08-31-2008, 12:39 PM
pd154's Avatar
Default 08 rear glass hatch opening?
I bought a used 2008 that came with only a valet key. There is no interor button or switch to open it and nothing I can find on the rear hatch such as a key swich. I have ordered a couple of keys with the door unlock buttons from the dealer, is there a rear hatch button on these?
Thanks in advance.
Old 09-01-2008, 03:08 PM
4never's Avatar
Default RE: 08 rear glass hatch opening?
Depending on what model you got, some hatch won't open and some will (SE). As far as your key goes, it will probably only have what mine has: Lock, Unlock, and panic button. If you don't have the two original keys, you won't be able to program the keys so that you won't be able to start the car with the spares.
Old 09-03-2008, 03:48 PM
Manybrews's Avatar
the glass will not open on the 08s. Only the hatch, via the handle.
Old 09-06-2008, 12:04 PM
pd154's Avatar
It may be that it is not designed to open,however it seems odd as the glass has its own separate hinges and the wiring to the defrost is coiled, so looks designed to be opened. Seems odd that they would spend the extra money on these items for nothing. However this may be. If so, Anyone know what parts I need to "hack" this?
Old 09-06-2008, 12:17 PM
mitsupartsman.com's Avatar
you will need to drill or replace the glass and add shocks and a handle
here's the illustration from my web page
Old 09-06-2008, 12:23 PM
pd154's Avatar
OK, thanks, I will go to the dealer and take a look at the layout of one that opens.
Old 09-07-2008, 07:28 AM
Manybrews's Avatar
ORIGINAL: pd154
the parts were used until phased out totally.
there was no "extra money" spent on them, as they originally did open from 04 to 07. But then mitsu realized exactly how stupid a feature it was, and stopped installing it.
if you do get the glass to open (and you can, manually), you will tear the defroster tabs off the glass depending on the production date.
Old 09-07-2008, 11:55 AM
pd154's Avatar
Mine must have been an early production date if they built them as you believe. Mine has the coiled defrost wiring so the tabs do not get ripped off, and of courseit has the hinges.
nOOb sauce
08-13-2012 11:39 AM
jerv22
10-15-2010 10:35 AM
redturboeclipse
15
02-25-2010 05:26 AM
cubsfan
01-28-2010 09:10 AM
AutoBodyGod
04-26-2006 07:18 AM
Quick Reply: 08 rear glass hatch opening?
