Drivers side floor board wet
I suggest you try looking at the "Endeavor Water Problem" thread (last post was a day or 2 ago) for the answer to your problem. On my '04 Endeavor, there is a line that connects to the a/c compressor that gets clogged (causing water to back up in the little "collecting tank", which once full starts spilling into the cabin on both sides of the center console) and you just have to go in with a air compressor and blow the line clean. Good luck!
a/c water leak
We have resolved the problem with the water forming under the floor mat on the driver's of the car....My wife, after searching, and getting touch with Mitsubishi, found out that it is a manf. defect due to the drain hose from the a/c to being discharged out, is too short from the manf. and therefore it was corrected, without any charge, by the dealer..note, the entire front panel had to be removed to correct the problem..it took a couple of day's to be done at our dealership. Good luck, check with Mitsubishi home office if you do not get any help from your dealership.
gfowler55
09-12-2010 09:05 PM
