Drivers side floor board wet
Old Oct 13, 2011 | 02:49 PM
daring's Avatar
Default Drivers side floor board wet
Hi, I have an 07 endeaver and the drivers side floor board and carpet is always wet. I can't find a leak anywhere. Any ideas?
Old Oct 18, 2011 | 01:53 PM
jpweaver's Avatar
I would like to know the answer also, my wife drives our Endavor more than I, and she has been taking out the floor mat to drie it, and carpet on the floor remains wet. Could this be a manf. defect?
Old May 30, 2012 | 04:31 PM
4beussinks's Avatar
I suggest you try looking at the "Endeavor Water Problem" thread (last post was a day or 2 ago) for the answer to your problem. On my '04 Endeavor, there is a line that connects to the a/c compressor that gets clogged (causing water to back up in the little "collecting tank", which once full starts spilling into the cabin on both sides of the center console) and you just have to go in with a air compressor and blow the line clean. Good luck!
Old May 31, 2012 | 11:12 PM
mxmikie's Avatar
its the a/c evaporator drain
Old Jun 1, 2012 | 11:44 AM
jpweaver's Avatar
Default a/c water leak
We have resolved the problem with the water forming under the floor mat on the driver's of the car....My wife, after searching, and getting touch with Mitsubishi, found out that it is a manf. defect due to the drain hose from the a/c to being discharged out, is too short from the manf. and therefore it was corrected, without any charge, by the dealer..note, the entire front panel had to be removed to correct the problem..it took a couple of day's to be done at our dealership. Good luck, check with Mitsubishi home office if you do not get any help from your dealership.
rsm1979
Dec 8, 2021 11:36 AM
dswa5
Feb 23, 2015 10:23 AM
gfowler55
Sep 12, 2010 09:05 PM
Gday360@gmail.com
Jun 30, 2010 10:11 PM
dott
Jun 24, 2009 05:53 PM
