Subwoofer Endeavor 04
Old 07-15-2014, 11:13 AM
static x's Avatar
Default Subwoofer Endeavor 04
I have a endeavor 04 with infinity sound system, but I have a problem with the subwoofer makes a lot of interference with the movement of the truck on the road,
have to spend some tutorial or pictures of how to remove the subwoofer?
Thanks a lot
Old 07-15-2014, 07:10 PM
TechnoGeek's Avatar
Default Woofer Access
I removed the Spare tire cover, then the bolts that hold the Cargo loops, then the small deck to the right of the spare tire cover, then three Phillips Screws, then worked the cover off. I couldn't locate the needed info about the speaker so i decided to try to fix the speaker myself since it would toss it if i replaced it anyway. I noticed the issue was that the flexible ring around the outer edge of the speaker cone. I carefully applied Silicone Rubber around the cone where it mates with the speaker frame. I let it dry 24 Hrs reassembled and all has been good for over 9 months.
Good Luck!
Old 07-16-2014, 10:16 AM
static x's Avatar
Thanks for your answer friend, hey another question
Know where aplificador is located in the endeavor?
Old 07-16-2014, 08:17 PM
TechnoGeek's Avatar
Default Amp Location
No sorry I do Not. I guess I always assumed it was part of the main Radio/Cd unit in the center dash.
FAUEE
03-02-2011 12:18 PM
zontarh
04-02-2007 03:52 PM
00Mirage
06-12-2006 11:56 PM
5Tizzle
01-30-2006 09:46 AM
Stealth691
08-18-2005 04:01 AM
Quick Reply: Subwoofer Endeavor 04
