Turning engine but not starting
Old 01-19-2015, 06:47 PM
TheMitz's Avatar
Default Turning engine but not starting
Hi guys, My car turned off driving on highway,for unknown reason just turned off, engine turns . I replaced timing belt ,cam and crank sensors ,i checked fuel relay good, fire to spark plugs good , i tried starter fluid but to no avail.any suggestions?:
Old 01-20-2015, 03:12 AM
Akzle's Avatar
battery. Compression.
Old 01-21-2015, 07:14 AM
TheMitz's Avatar
Hi there, well did further searching not good , checking ALL my spark plugs 2 had water not much but , doing compression check this morning . I'll keep you updated
Old 03-06-2015, 04:27 AM
tony_jaa's Avatar
An auxiliary starter gets the turbines turning fast enough to make the compressor blades create enough pressure for combustion to occur to keep it going on it`s own. Additional fuel flow gives it enough to create thrust and propulsion.
Psyclone
03-17-2022 09:12 PM
Jmwatson14
01-13-2016 06:14 PM
WxDarklingxW
11-16-2012 07:57 AM
bengie501
09-17-2011 02:02 PM
noel380
1st Generation
11-08-2006 10:53 PM
Quick Reply: Turning engine but not starting
