97 m sport dont start
Old 04-23-2011, 12:26 PM
ERIC G's Avatar
Default 97 m sport dont start
Hi, got an 97 montero sport, the problem got no signal in the coil, the spark plugs cables are ok they got current, may be the computer or the module, any help!!!!!!!
Old 04-23-2011, 01:20 PM
mothman52's Avatar
Wow, your Montero sure has a pointy nose!
Welcome to the forums, Eric. Check your coil's secondary resistance, i.e. one lead where the current goes in and one where the current goes out — you should get 12.1 ohms. any more and your coil is bad. Also check the primary resistance, between the two little metal connectors where the current goes into the coil on the low voltage side — there you should be reading between 0.72 ~ 0.88 ohms resistance.
Do that and let us know what you get, and try not to drop anything overboard
Old 04-23-2011, 02:26 PM
ERIC G's Avatar
Thanks mothman52, i will check it & let you know.....
Call-_me-Jordan
20
08-31-2013 07:31 PM
michaelsgst
02-27-2009 12:08 AM
5star
10-29-2007 11:26 AM
xp8ntballkid309x
07-12-2007 08:30 PM
99eclipseguy
09-29-2004 06:33 PM
Quick Reply: 97 m sport dont start
