ETACS options customization
#62
I agree with Vadimus as the error message is about a file that is on C: drive not on the DVD.
Also did you kill your antivirus (I tried with and without and it is needed to shut it down) If you are nervous just unplug the Internet or shut the Wi-Fi.
Do you defrag your C: drive as major fragmentation will cause time delay in writing files as it has to break it in many small pieces.
Lexia 3 and PP2000 are not fully windows programs more like MS-DOS.
PS if you have more space on a second drive like D: you can send it there.
#64
This is my second attempt at using PP2000 to force door unlock on Park
Both case I was told "Write Failure" and it did not ask for a PIN number
I tried something else in a different area and this time was asked for a 4 digit number... (Not 5) obviously it failed since I don't have this one.
I tried the LEXIA but as you said it did not work.
Since I don't have the MMCS I will persist and remove the software and reinstall it just in case.
PS I reinstated (using the FAST key) the two setup lost last time when I initialized the Auto lock, the horn on lock needed to be redone but and funny enough as soon as that was done the second one i.e. unlock all door at once came back by itself.
#65
#67
Success, I could finally install the program. The problem was the antivirus software, thank's for your help
Now I have oe more question, for Lexia3 and PP2000 activation programs the computer must be connected to internet and have connected the interface tool?
#68
Activation should be performed offline.
#69
NO don't connect to the internet
YES connect to the car but do the activation manually using F3 to select.
Check the pictures in the KeyGen directory
LEXIA3 installation :
- Install v 45 first
- Then, navigate all the way the in the PP2000 10A&lexia v46 UP dir and find update_lexia_346.22.exe
- Run this v 46 updater pointing to the same location you chose in the v 45 install
When you are connected to the car and ready run the LEXIA3 icon.
- The v46 upgrade will be performed automatically at that point, simulating a web upgrade.
- Do the activation and make sure you use LEXIA-346 since you are updated
You will do just one activation that way otherwise you need to re-activate after the upgrade.
The same procedure should be used when you install PP2000 for the Peugeot 4007
#70
0k, no intenet connection for activation. What about antivirus software, I also turn off?
So, the tool must be connected to both the computer and car for manual activation?
I'm so sorry for so many questions
