please HELP ? NEED PARTS ???????
I need a torque convertor for a 2008 mitsubishi outlander . Automatic 4x4 . Japanese made .motor number 4b 12 (4 cilinders ) im in nicaragua and here they dont sell parts . Please tell me where i can find it have been looking for 6 months now , just want my truck on the road again . Thank you all for reading and replying .
They are availble on ebay, for example 10 13 Mitsubishi Outlander 2 4L FWD Automatic Transmission Assembly 74K | eBay
You can't buy just the torque converter, even if you are in the united states. Trust me, i've looked. You have to buy the whole transmission.
But are you sure you need a torque converter??? The 4cylinder has the CVT transmission, you sure you're not having a problem with the CVT transmission, which are commonly known to shudder??? The nissan pathfinder just had a large recall on this problem, and shuddering issues are common on CVTs.
CVT stands for "continuously variable transmission", meaning instead of gears, it uses a belt which stretches on one side and contracts on another to simulate different gear sizes and therefore ratios. Essentially, you have an infinite number of gear ratios.
I would do as much diagnosis with the car in tact before taking anything apart. Do you have a check engine light or anything??
How did you come to the conclusion it was a torque converter. Several things can give you the same feeling as a bad torque converter. Several things can make the car shudder like a bad wheel bearing, bad axle etc....
To replace a torque converter or CVT belt, you'll have to take the transmission off, which is alot of work. I'd be sure it's not a sensor, a hose, or something else causing the problem before i do that.
doesnt just shudder , it makes a loud screaming sound and loses power . it has been in pieces for months now the transmission is not in the truck , hasnt been for a while . the mechanic here thinks its the torque converter , im at a loss here i dont know what to do .i really do appreciate the time you are taking to respond to me to help me , thank you .
bluballz07
07-21-2008 05:46 PM
turismo69
09-23-2007 01:30 AM
