Winter tire question
Hey all,
Pretty stupid question, but since the winter tires and rims I use have different lug nuts, do you still torque them at ~80 ft lbs as you would the regular rims with the original lug nuts?
Thanks
Thanks
The guys at the tire shop said that torquing the steel winter rims to the same as the alloy ones for the rest of the year will be fine, even though they are a different type of lugnut and obviously on steel rims, not alloys....
So I put them at 80 ft lbs..just like I do for the alloys.
However, I did notice one of my winters is 2-3/32 lower than the other 3 tires!!! They suggested putting that on the rear and not using the 4wd very often...Bloody hell. He said that if left in 4wd it would wear out the differential. ugh
Measuring it it seemed about 1/3 of an inch difference in CIRCUMFERENCE.
I know Subaru states it cant be more than 1/4" for their AWD system..but mitsu doesn't state any specs...
I called a few dealers and they said it would be fine, but I am not really sure what they are basing that on since no one could point me in the direction of any written figures....
Thoughts?
dingledangle
07-05-2015 05:14 PM
