Saggy Rear 07 Outlander
Old Aug 15, 2007 | 06:47 AM
rcpax's Avatar
Default RE: Saggy Rear 07 Outlander
Could be another TSB that would call for the replacement of the rear springs, but hardly justifies a recall. If ever, this would probably be treated the same as the steering clunk for some early imported Outlanders last Nov-Dec 06. I have to look closer if my Outlander does the same...
Old Aug 15, 2007 | 07:19 AM
tcp's Avatar
tcp
I doubt there's any real issue. Car based SUV (CUV?)s generally have this trait. Airbags are an easy fix if the visuals are annoying to you.
Old Aug 15, 2007 | 11:35 AM
BoldlyGoingNowhere's Avatar
You cant go by the wheel well. They can have horrible optical illusions. To get a better idea of sag measure the area under the doors. First on empty tank, then fill, park where you were the first measurement then measure again.
I know for a fact that if I ever tow my boat I will have to get bags or something along those lines. If you have trailer brakes and the hitch sags too much you activate the trailer brakes every time you hit a bump in the road. Its quite comical but hard on the trailer and towing vehicle.
Old Aug 15, 2007 | 02:15 PM
biscuit's Avatar
I doubt there will be any recall. The rear is soft on purpose to give a smooth ride. I notice that mine sags when loaded with 5 people.
My solution will be to get some Bilstein BTS coilovers from Japan. In addition to improved dampening and adjustable ride height, the design makes the rear a true coilover (the spring goes around the shock). The factory suspension has separate locations for the spring and shock.
Old Aug 15, 2007 | 02:58 PM
OTO27's Avatar
I wonder how much the total cost of that would be, how high can they be adjusted?
Old Sep 7, 2007 | 06:04 PM
puwit321's Avatar
Default RE: Saggy Rear 07 Outlander - Solution
Thanks to the suggestions here, I installed a set of air bags to solve my saggy butt problem. I ordered a set of Firestone Coil Rite 4106. They didn't have an application for the Outlander but that was the set they recommended based on dimensions of the spring. And it fits. Took about an hour to install and now I can tow a boat without scraping my driveway. Since I had my wheels off...might as well paint the calipers!
[IMG]local://upfiles/13579/E7F9495E0DFA4BDC851CB57110B5CD9B.jpg[/IMG]
Old Sep 7, 2007 | 06:08 PM
OTO27's Avatar
Nice job man! post more pics with the wheels on, how high can you make it?
Old Sep 7, 2007 | 06:12 PM
abrcrombe's Avatar
Looking good, the calipers are very porsche-esque. I love yellow calipers.
Old Sep 8, 2007 | 11:29 AM
puwit321's Avatar
Here's a pic with the wheel on. This is with 35psi in the bags. It raised the car maybe an inch.
[IMG]local://upfiles/13579/DC5177A3DC2649FBBF83C67F01F7C6E4.jpg[/IMG]
Old Sep 8, 2007 | 11:35 PM
puddy's Avatar
are the alloys wheels you have been put on by you, they look different than my mine? (uk warrior spec)
nice paint job
puddy
