97 es (scatching my head problems)
Old Jun 28, 2009 | 12:49 PM
BrokeDad's Avatar
Originally Posted by Manybrews
its going to have nothing to do with the throttle body or the airflow meter.
Well then how about trying to help instead of always just finding fault with everything everyone else suggests ?
Old Jul 2, 2009 | 04:31 PM
baddog's Avatar
welp!! spent 362 bucks on a IAC motor (which the old one did test bad) but still having the same problems as before but I am getting a code this time P0505(idle control system malfuntion) and manybrews if you know what it is. then please enlighten me
Old Jul 2, 2009 | 04:45 PM
Do you have issues starting? Also did you get a check engine light yet?
Old Jul 2, 2009 | 05:01 PM
baddog's Avatar
got CEL with the new code(P0505) have no problems starting
Old Jul 2, 2009 | 05:02 PM
baddog's Avatar
disconnected the ground for right now was gonna wait till later and reconnect it to see if it resolves it
Old Jul 2, 2009 | 05:57 PM
The p0505 I believe is for the iac.
Old Jul 2, 2009 | 06:55 PM
baddog's Avatar
ok no good disconnecting the ground but got no code this time around and the car still has the stumble talked with a guy just a few mins ago from the local shop he's thinking the PCM might be causing it GOD I hope not
Old Jul 2, 2009 | 07:35 PM
Its not a pcm I can assure you that. Try checking fuel pressure and try locating a maf too so you can eliminate that from a possible cause. I'm still waiting for manybrews to come here and say something useful but he hasn't helped much.
I've searched online and I've seen people replace the maf and tp sensor and its fixed their problems. Anything is possible lol.
Petrus Van Graan
Apr 12, 2014 12:58 AM
jp2000
Jan 1, 2012 05:21 PM
acidz3ro
May 10, 2011 03:33 PM
5Tizzle
May 22, 2006 05:14 AM
Ludicris
Aug 30, 2004 02:08 PM
