Front End Shaking
Old Jun 8, 2006 | 09:22 AM
ictponder's Avatar
Default Front End Shaking
After I lowered my car, I noticed a slight shake when I accel around 25mph. I spoke with a Mitsu tech and he said that the axles on both sides are sitting at too much of an incline now and are not spinning correctly. He told me to get some 'offset' parts but I can't remember the names. Basically what they do is level out the axles so they spin like they are supposed to. Can anyone tell me what I need to get? I already have a front and rear camber kit installed, but it has nothing to do with camber, I just want my axles to be straight again.
Old Jun 14, 2006 | 02:12 PM
Default RE: Front End Shaking
i have never heard of that before
Old Jun 14, 2006 | 03:36 PM
XTREME's Avatar
Never heard of that before. I've a a few friends lower their cars almost completely to the ground and they never had problems with shaking during acceleration.
Old Jun 14, 2006 | 06:02 PM
00GalantMan's Avatar
I would check your tires. One of them may be out of balance. I had a bad shake in my car too, and took it to the tire place to get it rebalanced. Turns out they balanced it wrong and I had to go to another place, and they got it right. I say either a bad tire or bad balance...remember if it's in your seat in the rear, if its in your hands, its the front.
Old Jun 14, 2006 | 07:20 PM
XTREME's Avatar
I agree, have your tires balanced and make sure you don't have a bent rim.
Old Jun 14, 2006 | 11:26 PM
Hamx0r's Avatar
you could also check wheel alignment cause the wheels can be pointing in and creating the shake. because they recommend a wheel alignment with a drop in suspension.
Old Jun 16, 2006 | 11:31 PM
ictponder's Avatar
already had it aligned, still shakes...ill go get the tires rebalanced
ajl44
Mar 23, 2014 10:04 AM
SPELMANITE84
Sep 18, 2006 09:15 PM
Sands128
Jun 20, 2006 01:40 AM
merlinthecat
Sep 9, 2004 06:06 PM
SnSRacing
Jul 19, 2004 11:27 AM
