Towed 2000lbs over the limit!
Old Jul 1, 2006 | 05:58 PM
TheVerdict's Avatar
Default Towed 2000lbs over the limit!
the towing max is 3500lbs, but i towed 5500lbs on a uhaul transport with a camaro! the mighty endeav pulled thru! dont try this at home!
Old Jul 18, 2006 | 11:08 PM
lovinmud's Avatar
Default RE: Towed 2000lbs over the limit!
the 3500 lb max, that is the tounge weight. Not the entire thing. The wheels on the trailer carry the majority of the weight. Th tongue weight is " the weight from the wheels to the hitch." That is where Mitsu. gets its max weight loads.
Old Jul 19, 2006 | 11:28 PM
TheVerdict's Avatar
i belive u mean the tongue weight is 350lbs... the 3500 is the max rec. weight towing...
Old Jul 21, 2006 | 12:41 AM
lovinmud's Avatar
if that is the case i apolagize. but i think its the 3500 at the tongue
Old Jul 21, 2006 | 02:01 PM
dirtwagon's Avatar
The Endeavor is rated to tow 3500 lbs period. That's not to say it cannot tow more than that , it's just what mitsubishi feels it can tow safely on a repetitive basis factoring in the suspension, frame, braking ability, and drivetrain. Remember that they will rate conservatively, knowing that not everyone will watch their loads and weights carefully. If you towed on a Uhaul transport the majority of the weight was being supported on the towed vehicles wheels if it's the two wheel trailer that straps in the front two wheels. This means you are really towing the rolling resistance of that weight more so than the actual trailered weight. Nonetheless I would have hated to have been your brakes on that day. I also wouldn't like to put my CV joints through that much stress.
The second gen behemoth Camaro's still weighed in at less than 3700lbs, how did you get 5500 LBS of Camaro behind your Endeavor? I'm a Camaro fan and still dearly miss my modded 79.[] Post details and pics if you have any.
Old Jul 24, 2006 | 11:54 PM
careful.
thats the kinda thing that promptly destroys transmissions as they overheat and cook without you even knowing it.
Old Jul 25, 2006 | 12:58 AM
dirtwagon's Avatar
Especially on the light duty 4speed
Old Jul 25, 2006 | 07:16 PM
well, the endeavor has the heaviest duty of all mitsu autos in it, and a large trans cooler.
but they didnt take into consideration people overloading the truck, either.
Old Jul 25, 2006 | 11:42 PM
dirtwagon's Avatar
I stand corrected, I didn't give the 4 spd that much credit.
Old Nov 12, 2006 | 01:09 PM
TheVerdict's Avatar
the transport is 2000lbs, the 'maro is 3500, maybe less cause i have aluminum heads.....
mprojekt
May 7, 2013 01:36 PM
mredlancelot
Mar 15, 2011 10:01 PM
jpmontero98
Jan 7, 2010 11:54 AM
jpmontero98
Nov 20, 2007 06:06 PM
unreal23
Jun 24, 2005 02:07 PM
