question about warrenty
Old Aug 21, 2006 | 05:11 AM
Yokomo's Avatar
Default question about warrenty
There is a problem with my mass airflow sensor, does the Powertrain warrnty cover it? my car has about 52K on it.and if not is there a place i could buy it less then $183
Old Aug 21, 2006 | 06:56 PM
dirtwagon's Avatar
Default RE: question about warrenty
I do not think that it will be covered under the powertrain warranty- I believe that the only items covered are parts that use a flowing oil or similar terminology/ verbage.
Old Jul 18, 2007 | 12:34 AM
L0ngNuf's Avatar
I used to have a Toyota Camry 03 and it got wrecked and now am a proud owner of a Black Endeavor LS...Anyways, when I had my Camry, I had K&N Filter a little too late. Apparently m car was hesitating before specially when cold weather was in. Anyway, brought it to Toyota and said MAF was bad. They replaced it and was about 200 bucks poorer. I researched and it showed that the MAF is more or less a deflector which has opotransistor inside. So depending on the frequency of light that is deflected on it, it reports it back to the CPU via the optotransistor. Cleaned out the old one and installed it on another vehicle. All OK...Also make sure that your air filter is really doing the job. When you clean MAF, let engine run at idle for about 15 mins to reprogram computer.
Hope this helps.
Sodium
Oct 12, 2011 11:22 PM
Krystle
Sep 10, 2006 01:22 PM
EMonz57
Sep 10, 2006 01:17 PM
kyotiecub
Jul 7, 2006 03:37 AM
TheEngineer
Feb 18, 2006 11:03 AM
