Clatter engine noise
Old Oct 12, 2006 | 05:46 PM
work ahead of me's Avatar
Default Clatter engine noise
Hi everyone, I just bought a 1991 stock eclispe, it's a nice car but needs work starting with a clattering noise from the engine when I hit the gas....if I ease up on the gas the noise goes away......any ideas please??
Old Oct 12, 2006 | 06:10 PM
Default RE: Clatter engine noise
Maybe a bad motor mount. Or it could be that the engine is misfiring, do you notice any performance loss?
Old Oct 13, 2006 | 08:33 AM
yes there is a loss of performance (jumpy) after shifting gears, I've also noticed ilregular idling speed, engines got 171,000 plus miles on it, it's been sitting a couple of years before I got it...maybe it's just old gas, tank was 3/4 full when I got it and I've only put around 40 miles on it (drive to work car)
Old Oct 13, 2006 | 08:49 AM
it might just be lifter tick + an old tank of gas
Also... check the condition of the plugs and wires. That oculd be the cause of the loss fo perfoprmance and shuddering.
Old Oct 13, 2006 | 02:28 PM
shreff99's Avatar
If the car sat that long I would change plugs and wires, change oil and maybe switch to synthetic or blend to free up a sticky lifter, replace old gas with new and run a tank of higher octane through it with some cleaner...could the rattling be valves since the engine has high miles?
Old Oct 13, 2006 | 02:29 PM
well you should never switch to a blend after you are running synthetic
Old Oct 13, 2006 | 02:34 PM
shreff99's Avatar
I know....just saying if he is running a conventional oil right now then he could switch to blend from that
Old Oct 13, 2006 | 02:49 PM
he should go strait to synthetic
Old Oct 13, 2006 | 09:38 PM
shreff99's Avatar
I did that...but I was asking some of the service guys here at my dealership before I did that and they said it is actually better to go from conventional oil to a blend and then to fully synthetic...nothing bad has happened to mine yet though and nor will it either
Old Oct 18, 2006 | 04:59 AM
wanted to thank everyone for the great advice...found out today that the distributor had been replaced and not really driven since, so maybe it is a timing issue....still need to replace wires and plugs and get oil changed ASAP....also have a repair manual ( Chilton ) ordered....thanks again
phils06gt
Apr 18, 2012 12:10 PM
stephenson
Feb 26, 2008 05:23 PM
matt03es
Jul 29, 2004 04:04 PM
kylewatkins
Apr 19, 2004 11:48 AM
ricker625
Jan 18, 2004 04:38 PM
