should I??
Old Nov 30, 2006 | 04:18 PM
spyder4g63t's Avatar
Default should I??
i have arospeed springs and gr2s struts...the ride is kinda ruff and not to stiff i want something mor stiff and solid..more control..but i havent seen alot of springs with a 2 inch drop which i have now...and whats a good camber kit..i know i need one for the front..but rear not to sure...also what are some good performance tires..i have the alloy 5 star gst rims..lookin for the widest and biggest...theres kinda of a clearence between the wheel and the wheel well not to big i thinks its because i need a camber kit
Old Nov 30, 2006 | 11:38 PM
Default RE: should I??
Well if you want stiffer springs your probably not gonna get it from the ones with a 2" drop. Most of the good springs are around a 1.5" and for struts you could go with some adjustables.
Old Dec 1, 2006 | 12:22 AM
s techs are cheap and I love mine
Old Dec 20, 2006 | 05:44 PM
are s techs a two inch drop
Old Dec 20, 2006 | 06:17 PM
i think they are 1.5"
Old Dec 30, 2006 | 07:46 AM
silvercoupe97's Avatar
Sorry, I'm so late but, here's my input on the question.....
If you really want a "big" drop, I would suggest coilovers. It's a two bird, one stone kill there. You get the adjustability to 2"+ and, as long as you don't get the ebay brand and you'll have stiffer spring rates (assuming you contact the vendor with what you want). KYB AGX, Koni (preferred) are good shocks that will and can work with those conversion coilovers (you're going to have to get rid of the GR2s though)........or, you can get real coilovers (not the conversions) like TEINs.
Tires...put a camber kit on first (front and back). The stockers are only 6" wide, there's not much of a choice in wider tires.
I would imagine that you need camber for the front and back if you're lowered to 2"+/-. After a 1.5" drop, most cars need to correct their camber and toe. Where you get the camber kits are really up to you because there's plenty to chose from front and back (you can even do the DIY rear camber kit).
eclipse_rider
Mar 12, 2004 06:18 AM
Kolt19
Feb 6, 2004 12:31 AM
lunarcry
Dec 19, 2003 06:32 AM
2fast4u
Sep 6, 2003 06:44 PM
DeJa_Voo
Aug 11, 2003 01:11 AM
