EGR block off!
Old Dec 28, 2006 | 01:42 PM
bud660r's Avatar
Default EGR block off!
well when i got my new intake all of the hses and stuff that were conected to the stock air box are all just hanging there now, i have nothing goint to my header from the airboxany more, so how do i do an EGR block off ?
Old Dec 28, 2006 | 01:45 PM
VR4GARY's Avatar
Default RE: EGR block off!
Go to the 3SX website.
Old Dec 28, 2006 | 02:14 PM
bud660r's Avatar
and i am looking for?
Old Dec 28, 2006 | 06:02 PM
paintballproam's Avatar
just buy a block off plate off SBR or extreme psi or something
Old Dec 29, 2006 | 03:56 AM
silvercoupe97's Avatar
Yup, a block off plate and plugs for the hg nipples on the TB and the mid sized one that goes to the intake pipe. I might suggest a gasket for the blockoff plate too, I had a tiny leak from my blockoff plate and I used an old piece of tin to sub as a gasket...it's still working btw. Even an old or new, lol, soda can will work (assuming you do know that I mean to cut it to shape).
Might I suggest FFWD Connection.
They have a copper plate for just this reason
The copper alloy will embed with the mating surfaces and insure a tight seal...better than a stainless or aluminum plate.
I have an aluminum one btw , hence my suggestion.
Hey VR4GARY, bud660r has an Eclipse...I'm just saying
Although this middle one looks like ours.
Old Dec 29, 2006 | 01:46 PM
bud660r's Avatar
thanks alot for the clear answer silvercoupe!
it just a plate right nothing special about it? if so i could just make one out of alum "i work at a machine shop" we have alot of aluminum layin around!
Old Dec 29, 2006 | 08:49 PM
ORIGINAL: bud660r
Yup, any will work, just make sure that it's flat and you're good to go.
Old Dec 31, 2006 | 02:34 PM
bud660r's Avatar
is there any benifits to doing the egr block off? or is it just to get rid of all that crap from the stock intake!
Old Dec 31, 2006 | 09:39 PM
..that and a cleaner manifold+ and less gas milage (differs from car to car). I've got a nice big opening where my battery and EGR used to be
Old Jan 1, 2007 | 11:08 PM
How much worse gas mialage?
