turd ass eclipse
Old Jan 13, 2007 | 12:02 AM
95HGeclipse's Avatar
Default turd *** eclipse
well bought the car running fine for about five miles started tapping befor i even turned it off shot a rod out of the oil pan
Old Jan 13, 2007 | 12:50 AM
Default RE: turd *** eclipse
That sucks... did the car actually have any oil in it or was it bone dry?
Old Jan 13, 2007 | 11:06 AM
nah it was fresh and full of oil but soon as that rod went all the oil went with it
Old Jan 13, 2007 | 11:09 AM
something is not right. Where you beating on it anytime during or just before you could hear the knocking?
Old Jan 16, 2007 | 11:01 PM
nah i kepted that thing under 3000rpms and then it shot befor i even turned the car off i droped the oil pan and took the rod out because it snapped from the piston i'll take a picture of it and post it andshow how ****ed up the rod really is cause it came from the crank and the piston and the crank forced it out the oil pan
Old Mar 5, 2007 | 01:05 AM
tx2u's Avatar
I agree with Emonz57. No matter how weak the 7bolt rod is compared to the 6bolt, that **** shouldn't just snap without a culprit. If it was full of oil before you took off, more than likely you had an oil pump failure. I'd like to know if it's the #4 rod because the last 4 7bolts that I've worked either spun the #4 rod bearing or actually snapped it.
Slunder
Jan 27, 2008 10:56 PM
tampabaymitsu
1st Generation
Jul 12, 2007 04:40 PM
m3kgt_99
Jun 7, 2006 09:40 AM
m3kgt_99
Aug 15, 2005 10:54 AM
BurntGSX
Jun 28, 2004 06:51 PM
