2002 Galant Wont Start Need Advice!
Old Feb 18, 2007 | 03:30 PM
raff1ut's Avatar
Default 2002 Galant Wont Start Need Advice!
2002 Galant 2.4L having issues:
Background:
Car originally from deep south ... relocated to intermountain west and after first week it's dead in the water. Although the move is probably unrelated to anything I suspected fuel problems being that between here and there (2100 miles) the likelyhood of getting bad gas is pretty good.
Went to crank car to warm before taking kids to school ... it ran about 5 minutes .. put it in reverse then poof. Fuel level was getting low .. maybe bad gas .. usually kept her above a quarter tank. No codes thrown.
I put a small amount of fuel down the throttle and sheruns briefly (lol til the fuel supply runs out).
Thus I concluded it was either the filter or the fuel pump so I replaced it ... seeing that its an all in one deal! Well I replaced the pump within the little unit. Is there a built in filter as well? I blew thru the hoses on the module lol ... everything appeared free! Gesh whatever happened to old fashioned filters n pumps??
Any Ideas??!!! Need help here is only mode of transportation!
Old Mar 20, 2007 | 01:09 AM
IcEcuBe's Avatar
Default RE: 2002 Galant Wont Start Need Advice!
So did you replace the filter or not? Also check your fuel pressure at the fuel rail.You can also find the fuel inlet line to the fuel rail, once you find itcrack the line have someone turn the ignition key to runand see if fuel is getting that far.If your pressure is fine and the lines are clear, most likely its not a fuel problem.
Old Mar 20, 2007 | 01:13 AM
IcEcuBe's Avatar
^^^ Providing it reallydoes run when your pour fuel down the intake.
Old Mar 20, 2007 | 11:18 AM
raff1ut's Avatar
Was fuel pump ... then had to "reset" computer. Initial problem was fuel pump but after install I didn't realize I had to ... err.. reboot the system so to speak. I suppose bad logic was stuck in memory ... mine and the cars. Disconnected positive cable battery ... left off about 15 minutes ... car started fine afterwards. Hmm ... I miss them old 60's cars I grew up with ... things were so much simpiler ... at .70 cent a gallon.
Sk8eR_PR
Jan 12, 2014 01:51 PM
Bdassrider
Nov 8, 2012 07:28 AM
aron
May 8, 2010 09:07 AM
raff1ut
Feb 21, 2007 02:54 PM
Chnchapters
Apr 4, 2006 10:46 PM
