please help!!!
Old Mar 14, 2007 | 04:03 PM
tjbiker031's Avatar
Default please help!!!
ok i got a 97 gst, and the blinker is messed up on it. ok heres what going on. i bought the car from the dealer a few days ago, which everything works on it except for the blinkers and the dealer said it was just a fuse and he didnt have one on hand. well i put the fuse in and the blinker just flashes to the left on any setting, left, right, off....it just stays on and flashes left....but the flashers do work fine. does anyone have a clue whats going on? is it the switch or a relay?
Old Mar 14, 2007 | 04:22 PM
VR4GARY's Avatar
Default RE: please help!!!
Sounds like the contact on the switch is broken. If the contact broke loose, it may have fallen onto the contact for the left turn signal. This would cause it to blink no matter what position the turn signal arm is in. I would see if you can get into the switch without having to remove the steering wheel to fix it.
Old Mar 14, 2007 | 05:21 PM
RCJr9186's Avatar
something along these lines happened to me in my old accord. my right blinker would stay on alllll the time but i couldn't move my blinker arm at all. i had to have the whole arm replaced. it was like 115 bucks.
Old Mar 14, 2007 | 06:19 PM
Kaede.Noir's Avatar
I actually have a similar problem on my rs... whenever i put the fuse back on... the blinkers (both sides) stay on all the time..... but when i take the fuse out... and put on the hazards i only get the right one o_O hahaha like i said a thousand times, the guy who had my baby before me MADE A MESS!!!
Old Mar 14, 2007 | 07:04 PM
silvercoupe97's Avatar
Hey, I had the same issue too. Turns out I had some debris in my turn lever. I removed it without taking the steering wheel off by taking off the shroud and there are two (I think) screws that are easily removed because they point down. I opened the turn signal housing and the piece dropped out, I put it back on and presto.
If your issue IS with the signal box, that's easy to replace too. You will have to remove the center console and the radio since it's right behind the radio.
Old Mar 15, 2007 | 12:59 AM
Kaede.Noir's Avatar
Probably could be it.... but ill have to search further, i mean, i took out the turn lever as well (i dunno if its the same for yours) but it had this white box with two buttons one at the top and one at the bottom, i fooled around with it, tore it apart and then put it back together and noup... ill re-do it this weekend... any way to know if the signal box is working right? perhaphs some multimeter reading on it?
Old Mar 15, 2007 | 01:41 AM
Well, I would say that if the turn lever isn't moved and you're getting the turn signal light in either direction or both, then it's most likely the turn signal relay box. If the lever itself is stuck in the turn position, then it's most likely jammed with something. Those things are pretty inexpensive so it may be easier just to replace them. A junk yard may be a good source for them too.
There's only one difference to the lever between the Avenger (both 420a and 6g73 motored cars) and Eclipse (either motor) and that's the plug. I still have a spare lever from my Avenger and the one I have in the car now is from a 95 GSX. They both drop into the column but the Avenger lever won't plug in.
I had two because I thought my lever was just shot, but in fact it had a piece from somewhere in there break and it was jamming the lever movement. It would either get stuck during a turn or it wouldn't move, lol.
Old Mar 15, 2007 | 04:17 AM
Kaede.Noir's Avatar
Hahaha nice, that happened to me before in a nother car, but thanx very much for the advice im gonna go to a junkyard and get the relay box and hope is just that also, mr stupid (aka. old owner) somehow and for an odd reason, removed the whipers lever... so, i guess ill work lots there now (diagrams or pics of the column without covers would be great for those kind of heart) Thnx silver
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
