What does an oxygen sensor do?
Old Aug 1, 2007 | 10:05 PM
crow's Avatar
Default What does an oxygen sensor do?
Hi guys,
I recently replaced my servo on my 99 montero sport ltd and two days ago my service engine light is on i had it checked and was diagnosed of an oxygen sensor error but dealer tols me not to worry about i so now i would like to know what it really does...
Thanks in advance!
Charlz
Old Aug 2, 2007 | 01:26 AM
silvercoupe97's Avatar
Default RE: What does an oxygen sensor do?
It depends on which one you're talking about. Some motors have 2 some have 4...are there any with more than that, perhaps 5? Anyway, there's an upstream and downstream. The upstream tells the computer if the motor is running lean or rich and will adjust the air fuel ratio accordingly. Then there's the downstream which only monitors the cat and that's it. The downstream does not affect motor performance, only the upstream.
Old Aug 2, 2007 | 01:33 AM
I Drive Naked's Avatar
To what silver said, but in a nutshell.
The O2 sensor basically sends a readout to the ecu/pcm/whatever about how rich (too much fuel) or lean (not enough fuel) your vehicle is running.
It bases these reading on the exhaust gases flowing through the exhaust system.
Obviously, if it detects a problem, it tries to adjust the fuel/air mixture to correct it, but if it can't then you get a check engine light.
And if the O2 sensor goes out, you also get a CEL.
Boy.... some nutshell.
Old Aug 2, 2007 | 09:40 PM
crow's Avatar
ORIGINAL: Joshewuhh
What is CEL?
Old Aug 2, 2007 | 10:13 PM
Dusty Eclipse's Avatar
Check Engine Light.... all these acronyms can be found on the acronyms thread...
Old Aug 6, 2007 | 11:05 PM
crow's Avatar
My montero hesitates during acceleration after a full stop could it be because of a malfuntioning oxygen sensor?
Old Aug 7, 2007 | 09:24 AM
carlover626's Avatar
A failing oxygen sensor should illuminate the Check Engine Light, has the light been back on since the dealer looked at it? As far as maintenance have you been changing theair filter/ fuel filter / PCV valve / spark plugs as needed?
I wonder if you just need to catch up on some maintenance items?
Old Aug 7, 2007 | 08:32 PM
crow's Avatar
The CEL light has now been off but i still have that sort of mild engine hesitation during acceleration..i recently changed sparkplugs air filter is also good, what else could be causing this?
Parts here for a US version montero sport is hard to find i actually got the servo from australia..
mrbo
Jan 4, 2015 09:52 AM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
Teejay36
Sep 11, 2007 08:10 PM
Crispious
Jul 23, 2005 09:11 PM
