Engine Code P0170
Old Aug 19, 2007 | 03:06 PM
drakon's Avatar
Default Engine Code P0170
showArrow("7/15/2007 6:22:50 PM",156636,23,false)Engine Code P0170 - Fuel Trim Malfunction (Bank no.1). What means that and how to deal with it?
The car is 98 Mitsubishi Galant
Old Aug 19, 2007 | 08:53 PM
Dusty Eclipse's Avatar
Default RE: Engine Code P0170
Cars running too lean or too rich.. could be a number of things, but check the simples first.. like your air filter and whatnot.
Old Aug 20, 2007 | 08:00 AM
that code is usually a lean condition which could be caused from multiple things such as the injectors are clogged. Your air filter is bad, or you need to clean out the Trottle body. These are all cheap fixes. Maybe the fuel filter...ect.
Old Oct 23, 2007 | 07:08 PM
If you have acess to a scan tool you can use 2+2 to spray around the intake, injector o-ringsand t/b to see if you have a vacuum leak. If you do the o2 values will change dramatically.
evan-e-cent
Jan 5, 2015 04:26 AM
xgains
Jun 26, 2013 04:18 PM
menacemonty
Nov 12, 2012 10:45 AM
dsm1990gsx
Jan 24, 2009 11:16 PM
Natedogg89
Apr 13, 2008 08:54 PM
