Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
CEL p0170
Old Oct 17, 2008 | 10:46 AM
dsm1990gsx's Avatar
Default CEL p0170
My g/f's grandfathers 99 diamante has a check engine light p0170 I was going to replace the bank 1 o2 sensor but I am not 100% which is bank one and tried searching and found no straight answer. Any help is appriciated.
Old Oct 20, 2008 | 04:28 PM
dsm1990gsx's Avatar
Default RE: CEL p0170
Anyone?
Old Oct 23, 2008 | 03:21 PM
BEAT's Avatar
P0170 Fuel Trim Malfunction (Bank 1) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
It is simple oxygen sensor. you can go on line search for CEL CODES there tons of them. if you don't want to post the problem here
goodluck it is an easy fix. just check how many sensor on the car
Old Oct 23, 2008 | 03:40 PM
dsm1990gsx's Avatar
ORIGINAL: BEAT
Do you know which side is bank one?
Old Oct 23, 2008 | 03:54 PM
mitsupartsman.com's Avatar
Is p0170 the only code you have? does this car have 2 or 4 O2 sensors?
Old Oct 23, 2008 | 03:55 PM
bank one would be passenger side but only on a 4 O2 system
Old Oct 24, 2008 | 11:56 AM
BEAT's Avatar
You must have 2 I think but not sure
Bank 1 means probably near the engine. Bank 2 I think it is catalyctic converter.
if you have more 4 of them THEN I DON'T KNOW. 2 in the engine and 2 in the exhaust I think Tech will know
If it's Bank One CHECK MAF or Manifold you must have an air leak.
Fix it as soon as possible brokenO2 sensor might damage your car.
if you cant wait anymore buy the parts from Auto Zone. I think they sell BOSCHE O2 sensor for cheap but if you want Mitsubishi it will be more expensive
Old Oct 24, 2008 | 12:02 PM
BEAT's Avatar
I recommend to buy a new o2 sensor. if the CEL lights up again after cancelling it.
You might have another problem.
Do you have SRI or CAI? check the boot that is holding the pipe on the engine. it might be loose.
tighten it, check MAF it it's broken.
goodluck
CEL really makes me nervous when it lights up.
Old Oct 24, 2008 | 12:52 PM
dsm1990gsx's Avatar
ORIGINAL: mitsupartsman.com
Its the only code and its a 3.0 v-6. I know its an upstream o2 sensor but I am not familair w/ mitsu abt bank 1 and bank two. Fords, bank 1 is on the pass side and bank two is on the drivers side.
Old Oct 24, 2008 | 12:54 PM
dsm1990gsx's Avatar
ORIGINAL: BEAT
The car runs fine just has a cel so I can assume that there is no intake leak or any issues w/ the maf.
