Antenna Problems
Old Nov 26, 2004 | 06:29 PM
terylsdad's Avatar
Default Antenna Problems
Has anyone had problems with their automatic antenna not retracting? I tried cleaning and lubing it up, but with no luck. It will go up just fine, but when the radio is turned off it will not go down by itself. If I apply a little pressure on the top of the antenna it will go down, but only then. Any suggestions would be greatly appreciated! Thanks in advance!!!
Old Nov 27, 2004 | 06:35 PM
enrique's Avatar
Default RE: Antenna Problems
Buy a new one. I tinker with those so much....a nightmare....the shaft will cost you around 60.00, remove the upper nut, remove old antenna shaft by turning radio on. Insert new antenna gently while some one else turns radio off... put back nut...easy...
Old Jul 13, 2005 | 02:37 PM
Mateusz's Avatar
I've got Mitsubishi Pajero (it's a european Montero) and my electrical antenna doesn't work and I don't know how to repair or change it.
Please tell me how to do it - do I have to remove fender to repair it ?
Old Jul 26, 2005 | 02:31 PM
atasic's Avatar
The above described procedure is correct, providing you inspect your antena mast, making sure that it is not broken. If it is not broken, than most likely the teeth are worn out and it needs to be replaced. When you replace it, make sure you correctly position the teeth prior to retracting the antena back in. If it is broken, than you will have to access the antena motor, open it and take the remaning part out and than replace your antena mast. The procedure is a little more complicated but can be done by an avarage skilled individual. I am an ALLDATA subscriber and that is when my subscription payed itself off. If you need a detailed instruction let me know and I will try to explain. It has been a while since I have done it.
jp2000
Jan 1, 2012 05:21 PM
rowanba
Jul 9, 2011 07:46 AM
billprew
Feb 4, 2005 02:14 PM
Knaackers
Jun 21, 2004 05:42 PM
01clipse
Sep 18, 2003 12:39 AM
