2001 Montero Ltd Dash Fascia removal
Old Jul 22, 2008 | 06:11 AM
lovinmrv's Avatar
Default 2001 Montero Ltd Dash Fascia removal
I have tried to search on this topic with no success, so my apologies if it is redundant.
I need to reset my anti theft code, so I need to get the radio SN. I have removed the 2 screws above the center display, and have tried, gently, to pry the faux wood trim off with no success, asI am afraid I will break it.
Are there any tricks to prying this off, or do I need to remove more dash parts first?
Thanks in advance
Old Jul 23, 2008 | 09:40 AM
lovinmrv's Avatar
Default RE: 2001 Montero Ltd Dash Fascia removal
Anybody?
Old Jul 23, 2008 | 02:05 PM
lichan's Avatar
The 2001 is different from the '97, but I took out the ash tray and removed its holder and the code was also on the bottom of the radio. It may take a flash light and a dental mirror or a younger set of eyes . . .
Old Jul 23, 2008 | 02:39 PM
lovinmrv's Avatar
Thanks, Lichan,
There is a 6 cd changer under the radio and on top of the ashtray. That approach won't work.
Old Aug 12, 2008 | 03:41 PM
23dozer23's Avatar
I am having to reset my security code in my 2001 Montero Ltd as well. I removed the two screws above the clock. That loosened the top of the fascia. I took a flathead screwdriver and stuck it in between the fascia and the dash. I did this all the way around the fascia. By doing this the fascia popped loose. If done correctly, you should be able to take the fascia off now. It will still be connected by the electrical cord of the flasher button.
Good Luck.
Old Mar 30, 2009 | 10:58 PM
humhai420's Avatar
Smile
Good Luck.
hey there i tried the same got scared when i tried to bend the fascia back did u manage to get it off
did not
Old Apr 9, 2009 | 12:43 AM
humhai420's Avatar
ok
after a big strong coffee
i managed to undo the cover
take out the top 2 screws
the vents on the eithere side put a small screww driver in . then pop
then on the bottom end o f the facsia just under the side of the stero
eithere side stick it in there and gently pulll
and then it allcomes out
JUST DONT YANK IT OUT
becuz you will undo the wires for the hazzrd switch
Swizz83
Mar 15, 2014 05:15 PM
Ozzyuk
Jun 20, 2010 04:57 PM
humhai420
Mar 30, 2009 11:24 PM
tsheahen
May 6, 2008 06:29 PM
dreamerboy09
Jan 24, 2006 11:42 AM
