Blower fan not blowing
Old Jul 30, 2008 | 08:42 AM
imchief's Avatar
Default Blower fan not blowing
Hi all. I have a 99 diamante LS with the didgital environmental control unit. My blower motor is is not working. the mechenic i took it to said the blower was good because he grounded the relay and the motor spun. I have also replace the ECU with one from Ebay that was a working unit but still no joy. Any ideas as to the problem or ways to test the components involved? I am an electronics tech so I can do what ever electrical testing needs done.
Thanks in advance
Joe
Old Jul 30, 2008 | 08:37 PM
Default RE: Blower fan not blowing
Did you check to see if you have power at the blower motor?
Old Jul 31, 2008 | 10:06 AM
imchief's Avatar
Yes, There is power at the connector going to the motor.
Old Jul 31, 2008 | 08:46 PM
Well try running a jumper wire to ground, maybe its bad since you have power @ the blower motor.
Old Aug 19, 2010 | 07:27 PM
Robods's Avatar
Default Blower Motor
Hello, I am having this same issue. What was your final solution?
Old Aug 21, 2010 | 08:19 AM
jseabolt's Avatar
Thanks in advance
Joe
Sounds an awful lot like my friend's problem. Is there any air whatsoever coming out of the side vents? On his car no matter what the setting is on, that's the only place air is coming from and it's very weak.
Old Aug 22, 2010 | 10:08 AM
Robods's Avatar
Turns out, my blower motor was bad. I removed the motor, applied 12 volts to it and it ran intermittently. I connected it to the car harness and turned the switch on but it would only run if I gave it a shove with my hand. Bought a new motor from autozone for 67.00 and now she's blowing like never before .
2004mo
Jul 14, 2021 02:14 AM
goose1970
Jul 4, 2013 02:31 PM
BrianB
Dec 14, 2008 04:53 PM
clipper965
Oct 30, 2008 03:44 PM
myron
Sep 29, 2004 06:24 PM
