Aux Input Noise
Old Mar 5, 2009 | 02:53 PM
anth600's Avatar
Default Aux Input Noise
I am getting a whining noise coming from my speakers that varies with the engine rpm's when I plug devices(mp3 player, sirius radio) into my aux input jacks. It only happens when I use the 12v cigarette lighter. I even tried to use the one in the armrest. If I use my mp3 player without plugging it into the cigarette lighter it sounds fine. Anyone have a solution to this problem. I know they sell ground loop isolator, do they work?
Old Mar 5, 2009 | 07:28 PM
klas's Avatar
I have the same issue that I reported a while ago and no solution. I am glad I can use your pain to feel better about the same issue. If you find a fix please do let us know!
https://mitsubishiforum.com/forum/sh...ad.php?t=28226
Old Mar 6, 2009 | 12:55 PM
BoldlyGoingNowhere's Avatar
Did you try using a shielded cable?
For what its worth I get the same problem on my aftermarket double din DVD player I installed. I run the sirius into the aux and its slightly noisy.
Way back when in the 70s and 80s we used to get this on our aftermarket stereos. Using a filter on the power going into the radio cleared it up.
I wonder if it would work for this.
Old Mar 10, 2009 | 03:13 PM
dekodan's Avatar
I installed a ground loop isolator. It fixed the issue. Go to Radio Shack or Best Buy's Audio installation department. $15-$20.
Simple plug n play.
Old Mar 10, 2009 | 03:43 PM
klas's Avatar
wow I am surprised no one had this solution before and 2 years later someone has the fix! Thank you!
drg2007
Feb 6, 2019 11:14 PM
BlueDev
Apr 2, 2007 09:47 PM
arius
Feb 22, 2006 09:47 PM
arius
arius
Feb 22, 2006 05:23 PM
