Question about valve clearance inspection
Old Mar 6, 2009 | 07:24 PM
darek_u's Avatar
Default Question about valve clearance inspection
Hi everybody
My '07 XLS has almost 30kmiles on the clock and it will be necessary to carry out a valve clearnane inspection and adjust as per scheduled maintenance table. Here comes the main question: are the gaskets under rocker cover reusable or I need to order new ones? Question quite important for me because I live in Poland and 6B31 engine is not offered yet on local market. Thus I need to order them in advance if needed.
Question for those who have already done this inspection: was it necessary to do any adjustement? Were the valve seats burned/used? Is it fairly simple operation or it takes a lot of time and effort to carry it out?
Old Mar 24, 2009 | 04:10 PM
alim's Avatar
I'm from Southen California. I have about 32K mileage. Called the dealer regarding the valve clearance issue and they said it's not required for the 30k service. What I will do is change the AT fluid. It's a V6
Old Mar 24, 2009 | 07:40 PM
you will honestly NEVER need to have it checked or altered.
Old Mar 24, 2009 | 07:55 PM
ShortyRider's Avatar
It takes a lot of time to do this inspection. I say is not worth it yet.
30,000 kms is way too less ANY inspection under the cylinder heads or the block.
Mitsubishi is just trying to make money off of you by this service. If you were to bring it to the dealer to do the inspection, they will charge you, bring your car to the shop, and not even do the inspection, because is just too new for that inspection. Dont let the service adviser convince you to do it. A lot of the service require on the service table is not necessary to do.
Save your money. There will be other service to do.
Old Mar 24, 2009 | 11:04 PM
darek_u's Avatar
thanks for the suggestions. i will skip this inspection.
rayf01
Feb 28, 2014 02:49 PM
rlmcrae
Feb 5, 2012 06:27 PM
guangui
Jul 30, 2010 09:57 AM
Margrove
Other Mitsubishi Models
Sep 10, 2007 08:02 AM
GARYMITSU
May 23, 2006 09:27 PM
