What kind of oil you put in your engine???
Old May 8, 2009 | 09:18 AM
steph1693's Avatar
Default What kind of oil you put in your engine???
Just for fun, what oil you're using?
I went to the dealer for a ««free»» oil change and ask for synthetic oil and they put Motul oil, i don't know this brand. I paid a difference of 40$ for synthetic instead of 80.00$. Normally, i put in all of my present and past cars Castrol Syntech oil and will do it for the future oil changes. I go to Costco and it cost me 42.00 $ cad for an oil change with 5W20 oil for my mazda 5, i guess it will be the same for my outlander, except maybe a little less expensive (10W30 instead of 5W20).
So only for my knowledge, what oil you're putting in?
Old May 8, 2009 | 10:12 AM
joe603's Avatar
Motul is 10x better than Castrol!!!
I use Royal Purple which is another true synthetic oil...
Old May 8, 2009 | 01:24 PM
Elisha's Avatar
Mobil1, AMsoil, Royal Purple are all top tier. Valvoline is decent too.
now i use whatever the dealership puts in.
it's hard to notice a difference in modern cars especially if you change them at the proper intervals. but synthetic makes a bigger difference in older cars.
Mobil1 made my 93 Infiniti J30 feel like a new car again!
Old May 8, 2009 | 10:07 PM
ruski's Avatar
I have used Castrol Syntec 5W20 once. And couple more times - Pennzoil Platinum synthetic 5W20.
Old May 10, 2009 | 02:05 PM
07outty's Avatar
mobil lucas valvoline
all full synthetics
mobil 1 fliters
Old May 11, 2009 | 02:32 AM
trapie's Avatar
I use Total Quartz Ineo ECS this is the one recommended for the 2.2 DI-D engine...
It is pretty good so far...
Old May 11, 2009 | 09:57 PM
azjake's Avatar
Valvoline 10W-30. The 10W-30 weight is used because of the heat in Phoenix.
Old May 12, 2009 | 03:27 PM
trapie's Avatar
I thought then you could use some 5W-50 for hot weather...
What I use is a 5W-30 and we have moderate weather here...
Old May 12, 2009 | 08:24 PM
azjake's Avatar
The 10W-30 is pretty standard for here in Phoenix. I've lived here 25 years and never had any engine problems using that weight.
Old May 13, 2009 | 12:54 AM
95GS Eclipse's Avatar
Default engine oil
Synthetic oils are all kept to a certain standard to be considered synthetic oil. Only real difference is each brand has a special additive to make thier a little better then everyone else's. I run Mobile 1 5w30 synthetic in my 95 and you can feel how much better it makes the engine run, almost like it is a knew car.
