fuel pump relay
Old Jul 22, 2009 | 12:19 PM
kinger's Avatar
Default fuel pump relay
were is the fuel pump relay located on a 2002 montero sport
Old Jul 23, 2009 | 09:52 PM
jgbrules's Avatar
in the fuse block under the hood. why?? they dont go bad.
Old Jul 27, 2009 | 01:29 PM
kinger's Avatar
put new fuel pump in still wont start sounds like it wants to start will start run for bout 2 seconds then die
Old Jul 27, 2009 | 10:43 PM
jgbrules's Avatar
not a fuel problem then. timing belt could have jumped, cam sensor could be bad, or your ignition key could be the culprit. i see that alot. you ignition key has a computor chip in it and it has to be programed to the vehicle. sometimes the key loses its program, and has to be programed again. is the green light on your dash blinking when you have the key on?? did you lose the key and have it replaced with a regular non chip key?? it wont start without that computor chip key.
Old Jul 28, 2009 | 03:58 PM
kinger's Avatar
there is no green light blinking(so what does that mean)
Old Aug 6, 2009 | 09:18 PM
jgbrules's Avatar
gonna have to et the vehicle scaned for codes. then go from there
blumaverick
Jun 8, 2007 05:19 PM
kenny
Aug 11, 2006 12:42 AM
mpwizard
Jun 25, 2006 03:23 PM
nstriglia
1st Generation
Mar 2, 2006 01:33 PM
audionxs
Sep 19, 2003 11:56 PM
