Mitsubishi
Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi 3000GT
Old 09-10-2009, 04:02 PM
3KVT 3KVT is offline
Send a message via AIM to 3KVT
Unhappy 93 VR-4 engine sputtering
Hey all,
I have a 93 VR-4 that has had a rebuilt engine and transmission. Everything ran fine after the engine was rebuilt, until a couple months ago. I was racing a 95 GSX on the street and I noticed my engine started sputtering at high boost and high rpms. The boost level sank, while the engine sounded like it was running rich. I've talked to a few friends with VR-4's and they suggested I do a boost test. I found a small leak in my intercooler (It is dinged up from a wreck by the previous owner, but not enough to hurt functionality). The leak is small and it doesn't seem that it could be causing the drop in boost that I see when I floor the car. Anyone had a similar problem or have any suggestions as to what's wrong with my baby? Any help is greatly appreciated.
Old 09-11-2009, 10:07 AM
Girly VR4 Girly VR4 is offline
I'd try spark plugs and wires too. Sputtering at high(er) rpm's usually is spark plug related if there are no other issues with the car.
__________________
1991 3000GT Automatic AWD Twin Turbo
1991 Stealth R/T TT - modified
1995 3000GT Spyder - sunny day car
1996 Stealth R/T - Amethyst Pearl daily driver
Old 09-11-2009, 11:41 AM
Sebba Sebba is offline
Send a message via AIM to Sebba Send a message via Yahoo to Sebba
I also agree with the plugs and wires route. Check for corrosion on the contacts etc... any signs of arcing or rubber degradation.
If everything appears fine, be sure to check the gap.
Also don't use those iridium plugs, Mitsubishi turbo engines hate them for some reason. Good ole NGK is what you should be sporting.
__________________
http://i39.photobucket.com/albums/e189/Sebba/Me-Cut.jpg
These cranks are made for walkin', and thats just what they'll do, one of these days these cranks are gonna walk all over you
Old 09-12-2009, 10:08 AM
Thanks for the quick replies. She's in the shop for a while but will be back soon. I never even though to check my plugs/wires or the gap. Seems logical now that I think about it. Can you explain why 3/S's hate those iridium plugs? That's what I have in it now, so looks like I'll be buying a new set.
__________________
1993 Mitsubishi 3000GT VR-4
Full exhaust (headers back), Blitz DSBC boost controller, Blitz turbo-timer, Apex'i BOV, K&N filter, rebuilt engine (to stock), rebuilt transmission (to stock w/ slightly larger 5th gear), cross-drilled front rotors, a few more secret mods
Quote:
In my experience, men go through far greater lengths to avoid what they fear, than to obtain what they desire.
Old 10-12-2009, 07:52 AM
Unhappy
Well, I got the wires and plugs replaced (Big thank you to Hans at Ground Zero Performance for seeing me and getting me in and out of his shop so quickly!!). The sputtering has improved drastically, but still persists. I found out that my rear turbo is going bad and starting to spit a little oil. Could that oil that's running in through my intake be causing the sputtering under heavy load/high boost levels? I thought it would just burn up, but can it cause these symptoms if the concentration is high enough? Also, my fuel system has 130K on it as well, should I consider looking at that? Maybe the pump or injectors just can't handle the high loads it used to. Any suggestions on where to go next would be greatly appreciated.
__________________
Tags
1998, 3000gt, boost, eclipse, engine, gst, high, mitsubishi, rpm, sound, sputter, sputtering, stealth, turbo, vr, vr4
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
