Check engine light on, scanner cannot connect to OBD!?
Old Sep 25, 2009 | 08:22 AM
mtc137's Avatar
Default Check engine light on, scanner cannot connect to OBD!?
I recently took my 03' Montero to a local auto parts store to scan the OBD for the error code and the scanner was "unable to communicate with the computer" Aside from the obvious (checking the wires in the OBD connector and verifying no debris is in there) why would I not be able to scan it?
The parts guy said there is sometimes a fuse for the OBD connector, but I cannot find one for it. Even if the scanner/OBD port connectors match up, could it be that the scanner they are using isn't compatible?
Has anyone else experienced a similar problem?
Old Sep 26, 2009 | 05:24 PM
mtc137's Avatar
Thumbs up Problem Solved
After checking the circuit diagrams, I discovered the multi display unit must be connected for the scanner to work. I had removed that a few weeks ago because the LCD failed and needs to be replaced.
djc1308
Sep 22, 2021 01:29 AM
elboy0712
Feb 15, 2015 07:22 PM
Lancer2006
May 14, 2012 02:18 PM
geo jf
Jun 30, 2008 12:50 PM
Stryker
Sep 16, 2007 08:36 PM
