Key Replacement Procedure
Old Sep 26, 2009 | 10:37 AM
JNMathews's Avatar
Default Key Replacement Procedure
Hi All,
I recently purchased a use '03 Galant that came with only 1 key. Because of the microchip, the dealer wants over $100 to make a 2nd key.
I found a thread on this site that identified a source for a replacement key. My question to you is: with only 1 key, can I authorize this replacement key? The Owners Manual very specifically says you must have two. I just wondered if perhaps I could use the same key 2x while following their procedure.
Thanks in advance.
Old Sep 28, 2009 | 09:43 PM
jgbrules's Avatar
dude, suck it up and go to the dealer and let them hook you up with a new key and programming. gonna run you Around 150.00. all these websites telling you to do this and that and you get nowhere. there is 2 ways to program that key. one without using the mitsubishi scan tool and one with. still have to have the pass code either way. its takes about 5 minutes to program that key. another 15 to twenty minutes for the parts department to cut the key. so make an appointment AND SAVE YOURSELF A BIG HASSLE.
Old Sep 29, 2009 | 08:49 AM
JNMathews's Avatar
Jgbrules...
Thank you for the advice. I suspect you are correct, I was just hoping to avoid a large expense because money is a bit tight at present.
lars
1st Generation
Jan 18, 2014 12:04 PM
Mazdaspeedster
Jan 14, 2013 06:57 PM
mrvivona
Jun 12, 2011 12:08 PM
mrvivona
Dec 9, 2009 06:50 PM
galanturd
Mar 24, 2005 02:52 AM
