Heavy rain, dash lights up, power steering lost
Old Oct 28, 2009 | 11:21 AM
Fe2O3's Avatar
Default Heavy rain, dash lights up, power steering lost
I'm hoping to get some ideas here on our 2001 Galant 6cyl.
The last few times it's rained heavily and I think it's when we've hit some standing water or just some heavy water in the streets, the dash lights light up and power steering is lost. Engine doesn't die and after 30 seconds or so of limping it will return to normal.
I'm thinking splashing water might be sort of shorting out something and then once the water drips away it's ok, but I'm not sure where to look. The power steering unit is up high in the engine, so that doesn't seem logical.
Fortunately, this has been happening in slow speed situations, but we are nervous about if this happens at high speed on an interstate.
edit: Back in July, I replaced both belts. Would getting wet enough cause them to slip and show these symptoms, then once dry return to normal? Perhaps I should try adjusting the belt tightness after this period of breaking in. I did tighten a tad a week or so after install.
Another related question: This car was bought used and I see no splash guards under the front bumper or on either side. Should there be?
Thanks for any input.
Old Oct 28, 2009 | 02:16 PM
yes, your belts are slipping due to the water. you probably dont have them tight enough. and yes, you NEED the splash shields. if they werent needed, they wouldnt be there.
Old Oct 28, 2009 | 05:46 PM
Fe2O3's Avatar
Understood. Can you tell me what guards I should have on this '01 Galant? All this one seems to have is fender well plastic liners.
My Lancer has guards across the front, under the bumper extending back a good ways. I'm thinking this car should have the same, although a coworker has an '00 that is void of the front guards as well.
blindwolf
Jun 4, 2011 02:27 AM
Monte98
Dec 8, 2010 01:46 AM
claytonkobe
Sep 19, 2010 12:28 PM
Leon04
Jun 8, 2009 03:47 PM
J .dot.
Jan 2, 2009 09:47 AM
