3gen gs spyder convert to dohc
Old Oct 29, 2009 | 03:21 AM
bcrego09's Avatar
Post 3gen gs spyder convert to dohc
i have the 4cylinder 2.4 liter engine
i need to know what kind of head i need to do this ive been hearing about evo9 head and the dodge neon. what Do i need as far as a head
Old Oct 29, 2009 | 11:45 AM
Killswitch's Avatar
evo 8. the evo 9 is a mivec i believe, so im not real sure if itll work. theres also some hyundai head that can be used. but other then that youll need the cams and head gasket, i believe you need longer head bolts or something along that line, i never really kept up with it a whole lot. the timing belt to go with the head also
Old Nov 5, 2009 | 02:30 AM
bcrego09's Avatar
is there any other vedicle dohc cylinder head i can use besides evo heads because there like 2000 dollars used
Old Nov 7, 2009 | 07:14 PM
no there is not. Why go dohc? unless you are turbo or sds it will not help you enough to warrent the $ spent
Old Nov 9, 2009 | 12:24 AM
bcrego09's Avatar
i have the turbo kit i jUST WANT TO HAVE IT DOHC B4 I PUT IT ON
Old Nov 9, 2009 | 08:46 AM
jason clipse's Avatar
no need to yell about it.......
Old Nov 9, 2009 | 08:17 PM
bcrego09's Avatar
i wasnt yelling the caps got stuck man. but do u kno of any heads that would work
Old Nov 11, 2009 | 07:37 PM
Evo8 head is going to be worth the $$$ if your turbo and building up the bottom. you will have a car capible of lots and lots of power. Not that you will be able to get traction
sixx00
Dec 16, 2013 09:17 PM
Paul J
Oct 26, 2012 04:18 PM
chmeftwc
Sep 18, 2010 03:23 AM
benshin12
Jan 26, 2010 08:03 PM
clipse420
Oct 12, 2006 12:30 PM
