Mitsubishi
Old 10-31-2009, 01:54 PM
Carl2002 Carl2002 is offline
Default a/c & heat Blower motor 2002 Montero
Where is the access to the blower on a Montero LTD ? Mine is making noise like bearing going bad, or maybe trash has gotten thru to the blower..
Old 10-31-2009, 06:54 PM
jrmdir jrmdir is online now
I'm assuming it's basically the same as my '99 - above the passenger foot well. The "ceiling" of the footwell should be made up of a plastic air plenum that is attached to the firewall and center console with push-pin type plastic inserts. Once you remove this plenum the bottom of the fan motor housing is right there. Unplug the connectors, remove the 3 screws and it will fall into your hands. (hopefull along with the offending leaves)
Ron
__________________
San Francisco Bay Area
1999 Montero, Anchorage Gray Metallic -193K Miles
Old 11-03-2009, 08:06 AM
Default Blower motor Montero 2002
Thanks...leaves and noise are gone. Took about 40 mins.
Old 11-03-2009, 10:47 AM
Good news!
Thanks for the update.
Ron
__________________
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
