boost leak/ power/ idk
Old Nov 3, 2009 | 11:13 PM
Hitmachine101's Avatar
Default boost leak/ power/ idk
hey guys,, just got my Lower IC pipe from dejon,, installed it today and it made a heck of a difference, i most definatly have gotten rid of a large boost leak but im still not satisfied
i think this car has more to give and im not really the greedy type to think the car can do more then it actually can --
did a couple of 3rd gear pulls through the rpms with the gas petal to the floor and each time the boost gague was reading 12-13 ilbs ( i have an injen intake and a 3 inch down pipe )
got a friend whose a dsm freek and he s telling me i should be seeing about 15-16ilbs of boost with the mods i have
he got in and drove the car and told me the clutch felt real soft compared to his other eclipses ( this is my first eclipse so i have nothing to go off of )
he thought the clutch was going ( mind you the car has 45K on it )
before i put a new t25 turbo in there and messed around with the IC and its piping to clean the car -- it was pulling great with no issues
even after i put the new t25 turbo in the car it was pulling great -- but i needed to clean the IC because it was saturated with crap from the last turbo and the car hasnt been the same since i dickd with all the piping and the IC ( the IC piping was stock and probably never touched in the 15 years this car has been in existance )
and before i bought the car the guy before me took it to the track and made about 8 passes on it -- thus the blown turbo i had to replace to the car unfortunatly was beat on
soooooooooo my questions are basically -- do you think the clutch is slowly dieing and slipping causing the load on the motor and boost gague to drop??? is there anything i can do short of buying a new slave cyc?? like would bleeding it with some fresh hydrolic clutch fluid help me out??
my buddie told me the clutch systems on these cars can be touchy and the slave or some component could be dicking with my performance
he also said i should go with a exceedy slave if i replace it... good idea??
ps... im not getting a ton of black carbon on the back,, so my boost leak wasnt that bad to begin with and i dont think i have a vacume leak either -- theres just little to no carbon back there so shes not buring rich.. at least its not sticking to the rear bumper for me to see....
and btw i really dont drive this car hard guys,, im a poor college student and i have a gf thats 2 hrs away from me so gas mileage is what makes or breaks me lol -- i just would like to get this car running as well as i can
thanks for the ideas in advance
regards
Old Nov 5, 2009 | 06:29 PM
any ideas guys?
Old Nov 5, 2009 | 07:55 PM
Your car is gonna run around 12psi w/o a mbc. Also have you done a boost leak test?
Old Nov 6, 2009 | 06:18 AM
I dont really understand the problem? You are running 12psi....that is fine, the mods you have wont make you run more than that without a MBC like DSM said. As far as the clutch its kinda hard to say because real soft doesnt mean there is a problem. It may just be that the kid hasnt used a stock clutch that has been worn. My stock clutch always felt soft because they have such a weak pressure plate. But are you actually having problems with it slipping during full boost? If thats the case then you need a new clutch.
As long as when you depress the pedal you get a good disengagement of the clutch and it grabs well when you release then i wouldnt worry about it.
Old Nov 6, 2009 | 09:50 AM
have not done a boost leak test, kinda figured i fixed that with the lower IC pipe from Dejon but seeing as im still having issues im gonna go and buy the necessary parts DSM showed me earlier in a thread and do that --
MBC is a manual boost control i assume correct? and ya i have one but its not hooked up yet,, i was planning on getting the car running right before i do that
and if the stock clutch has a naturally weak pressure plate then i guess thats the nature of the animal,,, it is clearly disengaging and engaguing,, when i get all the boost leaks to go away then im sure the clutch will show its true life
thanks for the help guys
Old Nov 6, 2009 | 06:19 PM
Yea the stock clutches suck. Definetly plan to upgrade that once you start adding some power because it will begin to slip
Old Nov 6, 2009 | 07:25 PM
made the boost leak tester today,, either going to hook it up to the tank back home on the 21 st or going to try to find a buddies down here at school -- appreciate the help guys and ya agreed on the stock clutch with its feel and the power potential
i do plan on eventaully going with a big g 16 turbo, bigger injectors, and a fuel pump
probably looking around 350 or so maybe a little higher on the hsp range -- thats all i want eventually out of this car -- especially with the all wheel drive and what not
what kind of clutch should i look into for that horsepower --
just a stage one street clutch or should i be looking into puckd clutchs??
EclipseGuy92
1st Generation
Sep 22, 2013 10:37 PM
TheRock0720
Nov 12, 2010 12:30 PM
miket674
Feb 17, 2009 01:36 AM
BrunoBoy650
Oct 18, 2007 12:47 PM
mr casual
Dec 26, 2005 07:00 PM
