heat problem
Old Nov 8, 2009 | 05:52 PM
juice58's Avatar
Default heat problem
2001 eclipse spyder
heater is only blowing out luke warm.car not overheating and a mechanic that looked at it says the heat doors are opening fine and the blower is working fine,and also the thermostat is ok,and car is not overheating.thinks it may be the heater core.
anyone run into this
thanks
juice58
Old Nov 9, 2009 | 08:43 PM
lenny's Avatar
Default Have you tried this?
I had a similar problem last year in my 01 Spyder. My coolant level was good and no leaks or coolant smell from heater. Like yours everything seemed to work except temp was low. I took it in to the local oil change shop and had the coolant back-flushed and changed. Heater has worked great since. This may or may not work for you but you probably need this done anyway. Good luck
Lenny
Old Dec 1, 2009 | 09:09 PM
westerlundjc's Avatar
yes i have a 02 eclipse gt and i did a back flush cuz my heater was doing the same but now the vents on the drivers side only blow out cold air while all the passenger side vents blow out hot air, and it doesnt matter which setting i have it on vent, floor, or defrost all driver vents blow cold any ideas please help
Charles Shaheen
Jan 8, 2014 07:13 PM
dekood
Jan 23, 2013 05:17 PM
angel_rae_23@yahoo.c
Nov 25, 2008 09:04 AM
funnelit
Oct 9, 2006 08:43 PM
markm
Jul 10, 2004 04:09 PM
