Wierd temperature display?
Old Nov 9, 2009 | 01:52 PM
newoutlanderfan's Avatar
Default Wierd temperature display?
ignore this post..figured it out.....
Old Nov 9, 2009 | 03:24 PM
azjake's Avatar
Are you saying at the moment she was turning the key, or in the case of fast key pushing the start button, she saw the line 3/4 to H, and then a second or two later once the Outlander was started the display returned to normal? If that's the case I wouldn't worry about it.
The gauges and warning lights most likely go through a self test when you start the vehicle so what you see for that second or two isn't important. If a warning light/message stays on once the vehicle is started, or the temp gauge goes up to H and stays there, then you have something to worry about.
wulls1313
Aug 24, 2005 01:03 PM
wulls1313
Aug 21, 2005 12:54 PM
Atownprepy99
Aug 20, 2005 01:00 AM
KillerEclipse
Apr 20, 2005 12:14 AM
Subiman91
Oct 5, 2004 05:41 PM
