Low side a/c pressure port?
Old Jul 10, 2010 | 09:51 PM
xratede's Avatar
Default Low side a/c pressure port?
Purchased an a/c recharge kit to boost my a/c and I am having trouble finding the low side port I think? I found the large aluminum pipe running to the compressor(the one that gets cold) and the kit would not fit. the port on the car has a pin in the middle of it and the recharge kit connector also has a pin in the middle also so Im stumped. The only other port is way too small to fit so Im stumped............
any help is appreciated
Old Jul 14, 2010 | 04:43 PM
mike9baseball's Avatar
i have a 2001 the low side port is always the larger of the two its located on the top left side above the windshield washer fluid...
if anyone knows how to get a ac low pressure line can you let me know... thanks you
Old Sep 8, 2021 | 12:54 AM
mikeg's Avatar
Default A/c Low Pressure Port.
I had a similar problem with my 84 Cordia and ended up buying a set of adapters from Aliexpress (China) for approx $24NZ. Now the canister top-up system fits ok.
mikeg
Sep 14, 2021 03:11 AM
cnc002
May 19, 2012 01:01 PM
mysterio707
May 16, 2008 12:36 AM
avachell
Aug 2, 2007 11:45 PM
zeanimal2001
1st Generation
May 29, 2007 01:22 AM
