'97 Montero Air Conditioning Question
Old May 21, 2006 | 11:17 PM
cnc002's Avatar
Default '97 Montero Air Conditioning Question
Hello all:
I have a 1997 Mitsubishi Montero LS and for the first time in 190,000 miles the A/C needs some R-134A. The problem is that I cannot find a low pressure test port to which I can connect my manifold guage set for testing and charging. I have traced the low pressure line (suction if you will) and can find no low pressure fitting anywhere. There may be one on the compressor but, if so, it is in a location that doesn't allow one to see it. I found the high pressure fitting right up front on the receiver/dryer unit, plainly marked and of the correct size.
If anyone out there has run into this before please let me know. My local dealer is pretty much useless.
Thanks,
Randy A.
Old May 21, 2006 | 11:42 PM
Default RE: '97 Montero Air Conditioning Question
welcome to the site, for your question you might want to post it in the tech help because no very many members come in the new section
Old May 19, 2012 | 01:01 PM
mxmikie's Avatar
the low side port is on the compressor .... its fun to get to
UltraSmooth
Jan 14, 2011 11:39 AM
Alfiboy
Nov 11, 2004 05:02 PM
