Question about Air Conditioning Light
Old Jan 13, 2011 | 10:19 PM
UltraSmooth's Avatar
Default Question about Air Conditioning Light
I just bought a 2010 Outlander XLS V6 and really love it. There's a question bugging me for the past few days and after reviewing the manual I can't really figure out. When I turn the vent mode dial all the way to the right (ON the front windshield defrost icon) the Air Conditioning light on the middle dial lights up. This seems a little strange since I have the heat maxed and am trying to defrost the cold window. Is this normal? I've been just pushing the dial to turn off the air conditioning light up to this point, but can I just leave it on and ignore it?
Thanks!
Old Jan 13, 2011 | 11:03 PM
tcp's Avatar
tcp
Default normal
AC dehumidifies the air which helps clear your windshield. Even in cold weather, removing moisture from the air is helpful in clearing the glass. Completely normal. Unless you live in a low humidity environment, leave it on.
Thanks!
Old Jan 14, 2011 | 06:33 AM
Thanks so much for the reply. Makes a lot of sense, just not used to seeing the AC light on in the winter
Old Jan 14, 2011 | 11:39 AM
Vadimus's Avatar
Most if not every modern car does use the AC if switched to windshield defog. But often there is no indication of this (except of noticable engine load increase).
Few year ago I was driving 2000 Mazda MPV so there was a common mod for avoiding such AC activation by cutting a piece on air selection fob.
So thanks Mitsu for letting us override and even un-program this feature if needed.
cnc002
May 19, 2012 01:01 PM
Alfiboy
Nov 11, 2004 05:02 PM
