Crooked Steering Wheel
Old Aug 27, 2010 | 03:05 PM
MAK312's Avatar
Default Crooked Steering Wheel
Anyone else experience a crooked steering wheel? The car rides straight so I don't think its an alignment issue? Is this normal or is this something that can wait until my first service call? Can it do any damage if left?
Old Aug 27, 2010 | 07:21 PM
RAMON-'s Avatar
Its a alignment issue. When you have a chance look at another Outlander. The steering wheel should be straight when the front wheels are straight. As for damage.....you might be wearing the front tires unevenly. You may be taking the chance of loosing control of the Outie if there is something loose, cracked or damaged. I wouldn't take the chance.
Old Aug 29, 2010 | 09:07 PM
ivanz's Avatar
Crooked? Like not a circle?
If you mean off-centre, then you are the first person ever to experience that on this forum. All cars have alignment performed at the factory...the machine that does alignment will fail to align the car with such a problem. So it is impossible for it to leave the factory that way. I would check to see if your dealer went for a joyride before you got it or somebody who has access to your keys.
Old Aug 29, 2010 | 09:54 PM
dnieves6's Avatar
i say u may need ur tie rod ends adjusted the only way ur steering wheel could be crooked is if u or anyone took the steerinf wheel off n didnt line it up right.
Old Sep 8, 2010 | 11:31 PM
ruski's Avatar
Mine is slightly crooked (off center) to the left. But the car rides straight. Been like this since new.
Old Sep 9, 2010 | 03:27 PM
alim's Avatar
The issue now will be if the dealer will honor to re-allign it for your as it has been a while since you purchased your outie. They may claim you hit a bump after receiving your vehicle and misaligned it yourself.
I hope they're nice enough to take care of you.
Old Sep 10, 2010 | 04:03 PM
alim's Avatar
he,he,....agreed. I also had alignement issues with mine. I now have the alignment checked every year and right after tire replacements.
PappiDread6
Nov 13, 2008 04:22 PM
runner45
Oct 16, 2008 09:34 PM
Punisher
May 25, 2005 01:39 PM
avalanchemike
Feb 8, 2004 07:18 PM
bshelton
Feb 2, 2004 05:17 PM
