Exterior Talk about your rims, body kits, and other exterior mods here.
Is this possible?
Old Apr 26, 2005 | 03:16 AM
Wesley0913's Avatar
Default Is this possible?
Ok one day I was behind a new Cobra Mustang which has 3 columns in its tail lights. When he turned his blinker on the most inner colum lit up, then the middle then the furthest to the right, they then shut off and restarted. On the new eclipses the have 2 slots under the blinker in the front, If I were to fabracate two blinkers under the top what would I need to do to have it light up similar to the eclipse? Would I just need somekind of trip switch with a delay or would I have to mess with more than just the wiring?
Old Mar 1, 2006 | 01:19 AM
reroutetoremain3's Avatar
Default RE: Is this possible?
you could place an auto-delay switch,(the same as in christmas lights) between the two blinkers, set up a wire that connects the two blinkers together, and put the delay imbetween, and youd be set
Welch
Jan 12, 2005 03:42 AM
Flipz
Jan 10, 2005 07:07 PM
BlackMirage752
Dec 6, 2004 06:57 PM
FatalJRA
Oct 18, 2004 02:58 AM
paulcook
Jan 6, 2004 02:47 AM
