Decoding my In-Dash Receiver
Old Feb 3, 2004 | 02:50 AM
vwgolf02's Avatar
Default Decoding my In-Dash Receiver
I have a 2001 Mitsu. Montero and I have a problem with my tuner, i need to get a code for it. It keps on asking me for a code. anybody here that has experienced this before? Or know anyone who could help me decode my radio?</P>
</P>
Thanks </P>
</P>
</P>
Old Feb 14, 2004 | 09:03 PM
fargoette's Avatar
Hello</P>
I have the same problem but have already learned that if I can get the face plate off and get the radio serial number, all I have to do is call the dealership and they will give me the code. My problem is that I don't know how to get the face plate off to read the serial number. Do you? The dealership wants to charge me $75.00 to get the serial number for me and recode it.</P>
Can you help me?</P>
Thanks, fargoette</P>
Old Feb 15, 2004 | 04:06 AM
vwgolf02's Avatar
You could get the serial number without even getting the face plate out. Just unscrew the two scews and pull that plastic molding out and on top of the reciever is the serial number.
Old Feb 15, 2004 | 05:32 PM
fargoette's Avatar
I hate to sound like a moron and I guess it is obviousthat I am a women but which two screws are you talking about? There are no screws on or near the stereo itself, there is a molded plastic frame(no screws)around the stereo but I can't seem to get that to budge and am afraid to apply too much force. I really appreciate any help you can give me.</P>
Thanks</P>
Old Mar 19, 2004 | 12:47 PM
JustMike's Avatar
Hope you figured it out....if not:</P>
The screws are on the top of the panel that surrounds the multifunction screen. The screws are pointing up, so you might have to get lower and look up to find them. They are phillips, and they have to come out in order for the **trim** panel around the radio/climate, and associated pocket recesses to come out. The rest of thepanel is held in with clips that **snap** into place, and you can work the top dash panel up with a screw driver to free it up somewhat. Be carefullas you don't want to scratch anything.You will have to *pull* some to get it to start to come out.The panel has the air vents hooked into it also.</P>
Once out- you can easily see the 4 screws that hold in each of theitems behind the panel.</P>
Hope this helps.</P>
Old Mar 20, 2004 | 04:40 AM
fargoette's Avatar
Thanks JustMike,</P>
Actually I did get if figured out and have my stereo back up and running. In my car there are no screws on the outside of the panel but I took a screwdriver and gently pryed the frame (**trim**) off. Once off, I had to remove the screws holding the stereo in place so that I could read the serial numbers. It was a snap to reinstall the stereo and slip the **Trim** piece back in. I called the dealership and they gave me the code and I had my stereo working again. Now I have the code stored in several places so that if my battery is disconnected again I can take care of it.</P>
Thanks again, Fargo</P>
Old Jul 26, 2006 | 01:47 PM
ntqman's Avatar
Default RE: Decoding my In-Dash Receiver
So am I to assume that once you get the serial number, the dealership will get the code for you? I am the second owner of my 01 Montero, and I just replaced the battery not knowing about the codes. My wife and daughter then tried about 3 times to enter a code, and it supposedly locked them out. Can I get the original code, or does anyone know if it has to be re-programmed? Thanks for any help...
Old Jul 27, 2006 | 06:51 PM
off roader's Avatar
Code's are not reprogrammable. You have to get the S/N from the radio and get the code from the dealer.
mitsucrazy
May 22, 2009 07:40 PM
oneslowEVO
Mar 26, 2009 08:12 PM
kbaborder3
Mar 3, 2008 09:38 PM
gilkeson
Feb 12, 2008 07:28 AM
Tmann26
Mar 17, 2005 02:43 PM
