I got one
Old Sep 18, 2005 | 04:38 PM
Superman369's Avatar
Default I got one
I bought a '91 Eagle Talon a few weeks ago and now my check engine light cam on. I ran the codes and come to find out its the Oxygen sensor and an EGR. What is an EGR? and how can i fix it quickly? thanx
Old Sep 18, 2005 | 07:08 PM
Sanguinius's Avatar
Default RE: I got one
EGR= Exhaust Gas Recirculation. EGR valve is located on the intake manifold. It is held in place by 2 bolts and has 1 vacuum line running to it. Shouldn't take you more than 5-10 minutes to replace. The O2 sensor will require a special socket to remove and install. Also shouldn't take more than 5-10 minutes to accomplish.
Old Sep 18, 2005 | 08:26 PM
slow420a's Avatar
If its a modded car then those codes are normal. Some people block off the egr valve b/c it puts hot exaust gas into the intake. The o2 sensor... it depends on which one is failing. If its the rear it may be because the cayt has been romoved.
Old Sep 19, 2005 | 01:11 AM
Sanguinius's Avatar
Good point I hadn't thought abuot that.
marshmallow746
Jun 10, 2022 10:20 PM
jlozano3k
Aug 25, 2006 09:57 PM
evokillah
Feb 24, 2006 02:37 AM
anko_kun
Feb 15, 2006 06:20 PM
Superman369
Sep 18, 2005 03:18 PM
