two timing belts or one timing and one???
Old Jun 9, 2008 | 11:01 PM
marshmallow746's Avatar
Default two timing belts or one timing and one???
so a belt in my 2000 galant broke and my car doesnt start or go or anything. there is one belt that os the timing belt and the other on ei have no idea what it is for. i called the auto part store and they were no help. anyone know what its for???
Old Jun 10, 2008 | 05:57 AM
Manybrews's Avatar
Default RE: two timing belts or one timing and one???
there are two balance shafts in you engine.
one is driven off the oil pump, which is driven off the main timing belt.
the other balance shaft is driven off its own little belt.
however, if you broke a timing belt on a galant, you now have severe engine damage. Your pistons have contacted your valves, so at the very least you have to remove and rebuilt the cylinder head.
Old Jul 30, 2008 | 04:10 PM
kzgalant's Avatar
I just had this happen, actually. Timing belt went at about 115000 miles ('03 galant). It wreaked havoc on my head. I got the valves and pistons checked out could've been a lot worse. Replaced entire head, which is better than the entire motor. Luckily, my guy works at an auto shop, so we got the part for near cost. It turned about a
$2500 job into just $1400. But yeah, don't try to start it. You'll just drain your battery. The other belt you're seeing might be the serpentine belt? Is it on the far left?
Old Jun 10, 2022 | 10:20 PM
Jamesgawlikowski's Avatar
Default 2.4 galant
The 2.4 is not a interference engine.
thats what i have.
I guess yall are talkin about yhe v6
Doelker
Nov 3, 2010 09:34 AM
itsmaheshp
Nov 21, 2007 02:16 PM
uiucgalant
Aug 21, 2006 07:48 AM
slag
Jan 26, 2006 01:01 AM
estraw
Jan 9, 2006 03:03 PM
